Ernie, Red GTD, has a deflating rear tyre on a Halibrand wheel, he has tried sealing it but it still deflates. They are 15" replica wheels, does anybody know where to get a replacement wheel as it appear to be the problem
Before that remove tire, look for pin holes in rim. seal with 2 part epxoy. This is a common problem.
If deflation rate is high replace wheel but for a tiny leak this will work. If other wheels don't leak you could ask for a replacement but when this happened with my Lola wheel's mfg. told me to try epoxy and it's held up.
