Ford 302 to Renault adapter and other bits
Is anyone interested in the bits in the photo
Adapter plate flywheel is later ballance, clurch unused.
Brake cylinders fitted then removed.
Try again on the picture
Will the adapter plate fit the 351 if so a price for clutch plate fly and cover would be apprecaited
cheers dave
Adapter should fit either 302/351....but if the flywheel
is balanced for a late 302 (otherwise known as 5.0),
it won't work with 351, which used early balance weight.
MikeD
Hi
Do you still have the adapter plate and clutch bits,
if so i'm very interested.
Ta
