I have a kit on the way here from Australia. It was supposed to be here in time for me to use it at Carlisle as a demo but it won't make it in time. I now offer it here. The good thing about this kit is that it is readily available to someone that wants to start their build quickly.
Here is a list of all the items it has.
Kit is a fast build kit price USD$ 39000.00 plus shipping. This includes the following.
LHD Rolling Chassis comprising of
Body chassis kit sandblasted and powder coated satin black.
Marine Grade Aliuminium floor fitted.
Suspension package fitted
AVO Shock absorbers kit fitted
Sway bar kit fitted
Steering Column & Ignition Switch fitted
Steering Rack fitted
Steering intermediate shaft fitted
Mota Lita steering wheel fitted
Peddle box and pushrods fitted
Brake and Clutch master cylinders fitted
Front Calipers fitted
Rear Calipers fitted
Handbrake calipers fitted
Front Brake Rotors
Rear Brake Rotors
Rear rotor spacers fitted
Brake hydraulic lines fitted
Brake Light Switch
Brake Braided lines
Slotted Brake rotor upgrade
Handbrake lever
Hand brake Cables
Module # 1
Aluminium panel set fully fitted
600 rivets fitted
Sealant Fitted
Clutch Hydraulic lines Fitted
Clutch Braided Line Fitted
Body Hinges powder coated satin black and fitted
Door hinges powder coated satin black and fitted
Door handle kit fitted
Door lock set fitted
Over centre catches
Body Locating Cones Fitted
Dzus Fasteners fitted
Door Seal fully fitted with door closure panels (puppies)
Body Straps fitted
Aluminium edge finisher fitted
Vaccum formed dashboard
Upgraded Wheels from Bolt on Halibrands to Pin Drive Halibrands
No Tyres
Full Body Fit, including opened NACA ducts. The body is ready for preparation for painting.
Full aluminium panel fit.
As well as the wheels upgrade this kit also has full glass kit, front screen, mid screen, rear screen and all rubbers.
Please do not confuse this with our deluxe kit. This particular unit has many labor saving things finished. The body has been completely fitted and all the hydraulic lines are done.
This is a great GT for somebody that wants his car done quickly.
Please give me a call or send me an e mail if you are interested.
602-243-3770
Sway bar kit fitted
Front Brake Rotors
Rear Brake Rotors
Brake Light Switch
Brake Braided lines
Handbrake lever
Hand brake Cables
Module # 1
600 rivets fitted
Sealant Fitted
Over centre catches
Body Straps fitted
No Tyres
602-243-3770
