Made mention of this in another post. The plastic covering over a fuse (as well as the plastic on the fuse itself) melted off, and fell on the floor. Did not have time to trouble-shoot it then, but after looking at it this evening, it appears to be either the fuse to the fan motor, or the power to the A/C clutch. I tried to isolate which, but the fuse itself got hot when the motor was on and the AC thermostat was in the 'off' position. Once I turned the Thermostat on to a point where the electro-magnetic clutch would engage, then it got REAL HOT REAL FAST! Motor speed also seemed to cause the fuse to get hotter, whereas it should be the opposite...(A fan on high speed should draw more current, but the switch [a simple resistor] should allow more current through). Now, I'm no EE, but I believe this is correct. Car is new, has less that a hundred miles on it (due to the aformentioned cooling issues referenced in another post) and I have done nothing to it thus far. Any other CAV owner suffer through an issue similar to this? Would appreciate any thoughts. I am guessing that a wire is pinched in the chassis somewhere. Will post the answer when I identify it.
Thanks again fellows,
Tom
Tom
