I installed my pedals a while ago. When I installed them, I put a seat in the car, sat down, and moved them around until I was comfortable. One thing I did was move them as far to the right as I could (I have right-hand drive) to minimize the degree to which I would need to cant my legs to the left. I also moved them back a little further than I really needed and thought that I could use the adjusting bolts on the pedal pads to move them back forward if necessary. I mounted the base plate to the chassis by drilling six holes in the chassis plate/floor pan. I know that others (Hersh) have welded theirs in but since I don't own a welder (yet) I used bolts and nuts.
Now I did all of this before I had installed the front bulkhead...which has holes drilled in it to accomodate the clutch and brake pushrods, among other things. I didn't want to fit that panel until I had installed my hydraulic lines, steering rack, and front sway bar.
So when I finally did install that bulkhead panel recently, I found that the brake and clutch pushrod holes needed to be oblonged to the right, indicating I had installed the pedals too far to the right. Furthermore, my brake pushrod interfered with the rubber bushing from my steering rack mount. Finally, I don't have a huge amount of pedal travel before the pedals contact the bulkhead. So it looks like I not only installed the pedals too far to the right, but maybe too far forward as well. Using a razor blade, I relieved some of the rubber bushing that was interfering with the brake pushrod, and I think it'll work.
It seems my options are (1) to relocate the entire pedal assembly, which would leave me with an extra six holes on the chassis/floor pan to plug up, (2) to make the existing location work by oblonging the holes and relieving the steering rack bushing, and (3) to relocate the pedal pivots on my existing pedal assembly so I can relocate the pedals without re-drilling the floor for a new base plate.
I guess what I'd like to know is what is the minimum amount of pedal travel that is acceptable before the pedals make contact with the bulkhead panel. If I do need to relocate the pedal assembly, what's the best method to plug up the holes on the floor pan?
I feel like a dummy when I find myself in situations like this, and I guess that's the difference between an amateur such as myself and the more experienced guys out there who can look several steps ahead and identify interference issues or other problems before they happen. Live and learn.
