WTB Crower Lifters and a few others
Lynn Larsen
Lynn Larsen
Crower solid roller lifters with HPPO option: PN: 66215H-16 w/ no offset is preferred. Will consider non HPPO set.
Other items left to get:
Comp Cam (Solid Roller) grind - FW XR268 R-10, P/N 35-769-8
Shaft Mount Rockers 1.6 ratio for AFR205s:
Yella Terra P/N:YT 6610
Probe P/N 11312
Jesel P/N KSS-516060
Harland Sharp P/N 90066
Pistons - 331 forged flat tops .060 over (may consider .040 over) with 1.165 compression height (will consider 1.175). For inline heads (2.02/1.6) and min -5cc but prefer 0 or + dome for 10.5:1 w/ 58cc heads.
Need the lifters the most. These are the only parts I need to take the R302 to the shop and start the machine work on it. I really need the displacement to keep velocities up in the intake and heads, but need to cut some costs. That is why I am looking for .060 pistons; these should be OTS items rather than custom. If you have some with a compression height of 1.175", these can work also. The 1.165 just give me a bit better piston to head clearance. The engine is NA so that is why I need flat top pistons to get ~10:5:1. My default on the pistons is Mahle.
Thanks,
Lynn
