Well - back from Lydden and a quick update.
The days events had to be stopped not once or twice, but FOUR times due to GT40 problems - oopS!
I was first - Roy had had his first practice and I was out for mine on nice sticky slicks, when 1.25 laps into run, at about 6000rpm - the oil pressure light lit up! causing me to pull off the circuit and requiring a tow to the pits. We had thrown the dry-sump belt, but looking at the data logging, from the warning light coming on (<30psi) it took me 0.3 seconds to get off the throttle and another 2.5s to switch off. (not too bad considering I also glanced across the the digital readout of oil pressure and had to brake and negotiate a corner all at the same time) - Stripped and rebuilt Drysump Pump on Sunday - all ok now..
Ray Christopher was second - a spin at through the corner at the bottom of Hairy-Hill saw him exit backwards and spew flames from his exhaust that would have set many hill climb infields alight - still - no other harm done
Then Roger had the most unfortunate incident of the group, his engine letting go as he powered onto the main straight at the end of his first practice lap - Spectacularly smokey with bits of 'rod n piston' pinging down the circuit - but also a very sad end to Roger's current season that has seen him on terms with the fastest and setting new records earlier in the year. He will be back at Brighton in Dave's R42 (driveshafts in hand no-doubt!)
And finally - Martin Weigold - who unfortunately managed to slither off the circuit at speed - drifting sideways - and catching a tyrewall with the near-side - doh! No major damage fortunately.
So - a bit of a manic day really - All events were caught on film (thanks - Tim) so some clips will follow (sorry chaps!) and a big thanks to Ray and Dave who allowed Roy and I to continue competing by double-driving their cars on the day. - cheers! /ubbthreads/images/graemlins/smile.gif
A full write up of event will be included in the next mag.
