Peter Delaney
I was hunting down suspension noises the other day & figured that some of them were coming from the rose or spherical joints - specifically, from those that can "float" like the ones at each end of the pushrods. When I had everything dead level, there was no load on these pushrods & I could easily rotate them to get a clunk at each end of the travel.
Idea - I fitted some O-Rings (about 2mm larger ID than the bolt diameter) between the washer & the ball on each side. When I tightened things up, the O-Rings expanded & slid out to let the washers bear against the ball as per normal, but the advantage seemed to be that the rotational play was gone & the O-Rings provided a bit of physical protection over the normally exposed parts of the ball - keeps dust & grit out, grease in.
I have only done the front so far, but the reduction of noise from the front end is quite dramatic.
Has anyone else tried this (or a better approach) ?
Kind Regards,
Peter D.
Kind Regards,
Peter D.
