I am having a difficult time with the selection of these for my DRB. It came with the standard 11.5 corvette rotors. the wheels that came with it would not work with any brand of calipers as the wheels were what I call two stage wheels. That is the inside diameter of the wheel has a step down mid way across the wheel decreasing the inside diameter. So those were sold. Now looking at other wheels that I am interested in, particularly TeamIII, their wheels have the same step with the warning that if the offset is too far, the calipeers will not clear(14" down to 13 3/16" I believe). I still haven't figured out how much is too much, even with conversations with TeamIII.They gave me the wheel measurements, but that didn't really help me.The original wheels I had had about 5" of offset(10" wheel measured from the inside of the wheel to the mating surace of the wheel), and the tires (295's) cleared the wheel wells by about 1/2 to 3/4 of an inch and were very close to the bolt securing the bottom of the upright. I really want to stay with the 15's if possible for the street as Goodyear and others still make plenty of brands with the 295 size. I am having difficuly figuring out:
1. How much offset to use on the rear tire.
2. Which caliper I could use with the original rotor that will clear the wheel.
3.How do the larger rotor and caliper line up with the original mounting bracket?
Does anyone have any numbers on how much backspacing you can go with on the 15" TeamIII wheels(10"). Am I just missing something here? Couldnot find anything researching this.
