Lynn, thanks for the info - I am assembling a file on the whole h'brake issue & I'll add the Lokar stuff. Big re-design coming up next year !
Yep, I am all too familiar with that little pre-load screw adjuster in the calipers - at my age, its a bugger to get down to even see it ! Then I needed an Allen key about 9" long to get to it - in the end, we replaced them with 1/2" longer versions to make access a bit easier.
I think that my problem came from inheriting '88 brakes, rather that the original DRB spec for '87 (drum brake type). The whole lever/cable setup was for the earlier ones & guys who have that are quite happy. With the '88's, if your lever/cable setup gets 1/2" pull on each side with a 1/2" pull on the main cable, you should be fine.
Kind Regards,
Peter D.
