I have seen the 1.5" size work more than adequately, but I did encounter a problem with one setup where the coolant running to the radiator up front went thru a pressure drop and would almost flash to steam at the end of the run, we solved this with a restictor at the outlet of the radiator, I believe it was 1" I.D. Also maybe soften up on the thermostat setting if you have to. It seems that the restrictor didn't affect flow at all and we were able to drop about 15-20 deg. in the operating temp.
Good luck
Phil
