All the UK guys, anyone got recommendations for place to buy sealed rivets? Thanks Brett
Brett James-McCall Moderator Jan 27, 2005 #1 All the UK guys, anyone got recommendations for place to buy sealed rivets? Thanks Brett
9 Graham T Jan 27, 2005 #2 Brett, Do you mean blind rivets ? That is without a hole right through or do you require solid rivets.You can also obtain rubber washered rivets. Graham @ GTA
Brett James-McCall Moderator Jan 27, 2005 #3 The ones that look like this Attachments 50992-closed1b.jpg 1.5 KB · Views: 277
S Mike Christian Jan 27, 2005 #4 These folks would have them I bet: Aircraft Spruce Europe David and Pat Dawson Managers of Aircraft Spruce Europe located near London, England and serving the U.K. & all of Europe since June, 1992. 9 Cam Cntr. Wilbury Wy, Hitchin Hertfordshire, England SG4 OTW Ph: +44-1462-441995 Fax: +44-1462-442228 [email protected] an aircraft supply house...you can look at the catolog online at www.aircraftspruce.com. Mike
C chris parker Jan 27, 2005 #5 brett i used buck and hickman to get the sealed rivots if that helps chris
9 Graham T Jan 28, 2005 #6 Blind rivets. You will have no trouble in sourcing these. I use DJ Evans in Bury St Edmunds and Ipswich fixings and fasteners in Ipswich but you will obtain them at most good engineering biased shops. Graham.
