Hi Joseph,
If my engine is overheating I don't want the fans to slow down - it's more a case of getting the fan speed you need at any given time.
Rather than having a fan either on or off at say 85 degrees this box of tricks slowly creeps the fan speed up starting at say 80 degrees and at 85 they are back on full as normal. It would mean if you have been cruising for a while and then stop at lights you don't suddenly get the fans kicking in.
The temperature is adjustable to whatever you wan't and also means the fans only take as much power as you need - putting less strain on the alternator.
I'm hoping on a day like today in the UK (3 degrees) that the fans wouldn't need to hit full speed at all.
