GTD Camber/Castor/tracking
I have the GTD build manual, with the recommended specs in. However, I was just wondering if they were ideal?
yes, I have done a search, but can't seem to find any recommendations.
Simon
Malcolm
For road use they are pretty good. I have used them for 15 years. Some use more negative camber particularly for track work. That depends on tyre size and construction. The standard settings make a fine starting point to give you a reference to know if any of YOUR mods make an improvement or not.
PLEASE NOTE THESE ATE THE DAX SPECIFICATIONS
But probably a good place for them to be posted for reference by other users
GT40 Suspension Settings
Ground Clearance Front 110mm
Ground Clearance Rear 125mm
Front
Caster 6 1/2 degrees nominal (set in production) Camber 1 1/4 neg degrees without roll Bar Camber 3/4 neg degrees with roll bar Toe in zero
Rear
Length Longitudinal Rear Links (bolt center to bolt center) 28" / 711mm Length Triangulated Bottom Arm (Bolt center to bolt center) 13 1/32" 331mm Camber 1 1/8 negative degrees
Toe in 5/32" / 4mm Top hole
1/8" / 3mm Bottom hole
May assist someone
