Hello,
Whilst strictly not GT40 related, I was wondering if anyone out here would be able to help me. I am currently searching for a suitable and reasonably priced transaxle to fit into an off road racing car. Unlike you chaps who have awesome cars with the awesome power to match, this would be fitted with a small 4 cylinder turbo motor putting out no more than 350hp and 400ft/lbs torque, but the catch is that the wheels are 33inch diameter, so the lower the gearing the better. Would anyone be able to steer me in the right direction of which transaxle has the lowest overall gearing (probably the one that is least desirable to the GT40 builders infact).
I have read through the various topics found with the searching, and understand that Audi may not be the strongest transaxle in relation to 1st gear/bearings, but keep in mind that currently we run a 2litre Kombi gearbox (which are getting insanely expensive ie 3kaus by the time you build it up), shifting them is like waving a stick in a bag of marbles, and a frustrated flat change normally spells the end of the gearbox.
I am also open to any other suggestions that you may have in regards to transaxle, the most common ones used over here are the UN1 renault, with has a useless 1st gear ratio, shifts like a garbage truck, and wide gears or the Kombi one mentioned above. Unless you are loaded in which case you can spend 25-30k on an albins off road box.
I am willing to freight a transaxle from anywhere within the world, as long as there is a better than 50/50 chance that it will be ideal. Exact gear ratios and final drive would be awesome if anyone has them.
Cheers Chris
Cheers Chris
