My build is utilizing parts from all over the place, some new, some used and some custom pieces. Because of this, the blacks aren't the same tone and some things are beat up. I was referred to a SEM product by a buddy that did some restoartion a few years ago and it works great.
The stuff is called SEM Rust-Shield Corrosion Control Coating. I am using semi-gloss part number 38103. It is self priming, goes on real smooth and is tack free in ten minutes or so, and does not have to be top-coated. If you need to paint any suspension pieces or brackets give it a try, you won't be disapointed. It is available in flat, semi-gloss and gloss black.
I bought mine at an auto-body suply store and the can says not for use to the general public, so you may have to look a bit to find it.
Brian
Brian
