Just like the hose clamp thread, all cable ties are not alike.
from
www.mcmaster.com
Nylon Cable Ties
Also known as zip ties, these cable ties are lightweight yet strong. All are made of nylon (unless noted) and have a temperature range of -40° to +185° F. UL recognized (unless noted).
Notchless Nylon Cable Ties
The body of these ties has a smooth, notchless design for infinite adjustments. The head has an embedded stainless steel lock. Temperature range is -40° to +185° F. UL listed (unless noted).
Specialty Nylon Cable Ties
High-Temperature Nylon Ties— Added chemical stabilizers permit continuous use at temperatures from -40° to +221° F. Color is black.
Fire-Retardant Nylon Ties— Meet UL 94V0 flammability requirements. Temperature range is -40° to +203° F. Color is off-white.
Chemical-Resistant Tefzel Ties— These ties are resistant to a wide range of chemicals, withstand high temperatures and UV light, plus meet UL 94V0 flammability requirements. Temperature range is -65° to +302° F (except for 70215K81 , which is -50° to +302° F). Color is blue.
Parched-Environment Polypropylene Ties— These ties will not become brittle in dry environments. They also withstand the effects of acids, alcohols, and salts. Temperature range is 40° to 221° F. Color is black.
