Is anyone on this forum able to supply me with the part numbers or sizes of the wheel (hub) bearings used in the original cars. Front and rear. Any information most appreciated.
Does the lack of response mean that NO-ONE on this forum has this information tucked away anywhere? If anyone has and could take the time to dig it up and post it here I would be most grateful. Thanks.
Hi Russ,
Original wheel hub bearings were a Timken taper roller bearing, pt number 18690/ 18620 for the inner and 18790/ 18720 for the outer, front and rear were same. These are a very common size for a bearing and are still available.
hope this helps.
Cheers, Boris.
