I installed the Powermaster alternator more than a year ago and have had excellent results...until a week ago. While on a ride, I noticed the voltmeter in the car was reading just over 12 volts instead of 13.8 volts. Soon, the alternator light started blinking on and off.
A check with a digital meter showed 12.1 to 13.1 volts swinging around at any rpm.
While removing the alternator, I noticed the power stud turned 10 or 20 degrees (easily) before the external nut holding the output wire came loose. To make a long story short, the internal nut on the stud had come loose and created a high resistance, high current junction between the stud and heatsink. It had gotten so hot, it melted the solder on one of the diodes, and the diode was laying loose by the heatsink. All the diodes checked out okay, so I simply resoldered the diode back to the heatsink, cleaned the stud/nut/heatsink junction, and reassembled. The alternator now puts out a solid 13.8 volts again.
I have written Powermaster to see if this is a common occurance or simply my bad luck.
At any rate, something to put in the back of your mind if you have a Powermaster with similar voltage problems.
Dave
Dave
