My GTD's radiator fan switch doesn't seem to be working.
The thermostatic switch on the radiator inlet is working fine, if the car gets too warm or the adjustment is turned up (down?) the fans cut in, but the switch inside the cabin has no effect. also the yellow light wired into the circuit is on all the time the ignition is on. Before I start to pull the dashboard apart, I'm trying to work out what sort of fault in the circuit would cause the switch to not function and the light to stay on, just to give me an idea of where to look. As far as I am aware, it is a standard GTD loom.
