408 stroker for sale UK
After some serious thinking, I have decided to go with a 302 in my new build therefore, my stroker engine is up for sale.
Dave Whitehurst racing 408cu in 351 windsor stroker engine. Has been in a road car for slightly over 1,000 miles and is consequently in as new condition.
the history of this engine can be verified by Dave whitehurst himself. The 408 that he produces has been dyno'd at 490 BHP and a similar amount of torque.
I would be happy to partially strip the engine for inspection, or deliver it to your engine builder for stripping/verification.
The engine comes complete with an aluminium flywheel, hi-torque starter motor, and H/D clutch. The engine also has an 850cfm (enlarged to 920cfm) double pumper carb.
Please contact me for further details and full spec. Cost almost £10,000 looking for offers around 5K
Simon
07802 463848
01708 224402
Steve C
Steve
Simon.....I'm trying to determin what engine configurations will pass my emissions needs of 220ppm HC and 1.2% CO. I note your engine for sale is a 408 and one of the engine combos I am considering is a 402 or 427 Windsor so I am very interested to know if you passed UK emissions w/ your engine and if your emissions test #'s are in line w/what I need to meet. If you did pass emissions w/ this engine did you need cats, and if so where did you place them, and if so was there any heat problemsw/ the cats......AND most importantly what cam did you use! THANKS Steve
Sorry Steve, As I'm in the UK regs are quite different I think. For an engine built with an old block like this one (for SVA puposes) the emissions check is along the lines of seeing if the engine smokes!!!! (visible emissions!)no cats etc I've never fitted this engine (it was originally going to go in a Cobra)so have never had to put it through the MOT test.
Simon
Simon
More details on the engine
Dave Whitehurst 408 stroker Engine 490 BHP, 480 lbs Torque
351 Windsor block
Block has been destressed, bored, aligned and decked
Crank is Iron, Lightened, Balanced, Heat Treated, Race Prepared
Flywheel is Billet Alloy with steel centre
Clutch is a Centre Force Clutch, Heavy Duty
Pistons are JE performance pistons
Speed Pro Plasma Moly Rings
Con rods are Eagle steel billet H Beam rods
Cam is Fast Road Flat tappet
High flow oil pump
Canton Sump pan
Heads are Dart Windsor heads,
Stainless Steel valves 2" intakes
Crane Roller rocker assembly
High Performance Valve Springs
Elderbrook intake manifold
Holly Double Pumper 850 modified
Ford Motorsport Rocker covers
