Hello, Is this a good UN1, simple ID question?
Good afternoon gentleman,
I am a new member and this is my first post, and in advance thank you for any help you may provide.
I would like a quick answer if possible if anyone knows it,
I have a type NG3-065 TYPE LOTUS EUROPA/FUEGO TRANSAXLE. I believe this is also called a 365-07?
Believed to be out of a turbo car.
My question is >>>
Is this considered a UN1, would it mate to the SBC with the commonly availbale adapters?
Also, is this a decent ratio trans, if anyone knows?
Thank you for any info and I do hope to become a more helpful member in the future as I gain more information and comeplete my 69 valkyrie build.
Thank you again.
Peace
Ryan
enter >>> the )) apex
Ohhhhh I wouldnt use the NG3 in anything except what it came out of.
I pulled one down from a 1982 Renault 20 TS. Yep 5 speed manual blah blah But it is a very small gearbox! The diff may have 4 spider gears but everything about it is tiny, axle shafts, crownwheel - the lot.
You would wind up peeling every tooth off a gear the first time you mashed the loud pedal.
If you do have one - use it as a study device. Pull it apart and see how transaxles and gearboxes work, then when you know all, guide it to the dumpster.
Thanks you, understood.
Yah, I need to rip into some of these and get a feel for what they loo0k like inside. Thanks for the help an direction.
Take care!
Ryan
