maximising speed in a corner
Recently I had a superb day out at Silverstone in my Prosport 3000 Spyder. After some flaffing about I managed to download the data from the car onto my laptop and began to analyse what I had been up to. This has lead me to thinking about how I can see if I am maximising my coner speed.
The data recorded includes lateral and longitudinal G forces and from these numbers a combined G force is also displayable.
If I can corner on the limit at say 70 mph on a tight corner and pull 1.5G laterally (I am making these numbers up for now) but on a 130 mph corner the G reading is down to 1.3G, can I go faster in the 130 mph corner to take the G reading up to 1.5G without going over the limit, assuming the car can go faster in the corner?
I mentioned combined G as obviously you get some speed scrubbed off by cornering which decelerates you or you could actually be accelerating which will also help fling you off the track. Therefore instead of lateral G as the benchmark, I believe I should be using combined G readings to see if I am at my cornering limit.
If this theory is correct, then the target is to get as many corners as possible to the 1.5G limit to show that I have maximised my corner speed. If a reading is lower than 1.5G then I should be able to go faster in that corner without losing it.
Any comments?
Any comments?
