Hello
I did think to use the ford spline.Because its very limited with Lotus/Renault High torque clutches.I have a pressure plate witch is 35% stiffer than stock.
But only with stock friction plate.
Where do I get a Ford sinter clutch friction plate, hopfully 235mm diameter...?
So I can use it with my pressure plate.For use this season...
I probably gona need a 2 or 3 plate clutch next year anyway....
Can you come up with some links?
Do you have any suggestions?
Thanks a lot this forum is very usefull
