Neal
I've put together a video system that I'm installing in my car. In another car I used a camcorder mounted to the roll bar. After much thrashing it finally failed. I began looking at lipstick cameras and other recording media and came up with the following setup.
Sony CCD 480 line resolution camera - $90
Neuros MPEG4 recorder - $150
BNC to RCA adapter allowing input into the recorder - $5
High gain microphone - $15
1GB Compact Flash Card - $20
Simple voltage divider circuit (12v for camera/mic, 5V for recorder) ~$5
Total cost - $285
The Neuros player is a compact flash-based digital video recorder. (No moving parts.) I looked at personal video players, like the Sony PSP, but most did not have video input capability. Those that did were in the $500 to $700 range. The down side to using the Neuros player is that you don't have a monitor to view the menuing. This proved not to be a problem as it has a remote. When you press the record button it automatically begins recording and a red LED is active until you press the record again. The file is stored directly to the Compact Flash card and can be downloaded to a PC in MPEG-4 format. a 1GB flash car has 200-500 minute record capability depending on the video quality setting.
This player is about the size of a DVD case.
I made a voltage divider circuit and run the camera and mic at 12V and the recorder at 5V. You would buy an off-the-shelf voltage reducer for $20 if soldering irons scare you.
When researching cameras I found those with the Sony chipset have better resolution and adjust to light more effectively. These are commonly available at security system supply houses. I mounted the camera and mic on the cockpit firewall. The camera is weatherproof so you could mount it outside the car.
I'll post some video when the weather clears. All-in-all the picture is quite good and similar to a low to mid-range camcorder at half the price. Best of all there are no moving parts.
Total cost - $285
