Hello this is my first post i have a audi 016 trans in my shop and was wandering if anybody might know what ratio it is the number on the top of the bell housing is AFC i have a 5N in my car now just wandering if its any different than the 5n or not
The 5N has a slightly taller 5th gear ratio because of the 4.11 final ratio. Some people have installed the 5N 5th gear into the other boxes to get a taller final gear ratio to lower RPM at highway speed. The other gear ratios are the same.
Have a look down at the bottom of the page. Notice how the forum automatically searches for threads that are similar and shows them to you. For better results you can use the search engine and specific terms.
I havent had a chance to try it yet i have a small block chevy in it with twin turbos and im still working on all that stuff at the moment i have driven the car with this trans for 2 years now. I will put the other in soon butt it will probably be this winter as i would like to get a posi unit for it first i would really like to find a 944 turbo box for the higher ratio. Looking at the spead sheet of the two boxes(5N-AFC) i think the AFC will be about 200 RPM lower in high gear butt i really need somthing even higher with the turbos as they have more than enough low end grunt for a higher ratio.
Here are the ratios for an 016 5N with the 944T 3.375 R&P:
Audi 016-5N w/ 944T 3.375 Diff. 1st 12.15 2nd 7.193rd 4.59 4th 3.27 5th 2.46
These are net ratio's (Diff x gear), hence 3.60 1st x 3.375 Diff.= 12.15, and so on.
Andy,
How many teeth are on the pinion of a 5N box.Can the crown wheel be changed seperatley.Auto 944s I think run 11teeth pinion 37 crown or 12pinion 38 crown.You end up with 3.45-1 and 3.08-1.
Are the R&Ps out of auto 944s suitable to fit to the 5N 016 box.
Every 944 Turbo manual I find the box is sold or the R&P is broke.
Any help would be appreciated.
Cheers.
The auto 944 is completely different. The R & P will not work in any 016/083 transaxles. If you want to spend the money, you could always buy the 944 turbo R & P new, although I can't imagine what it would cost.
There are usually turbo transaxles on e-bay. Keep an eye there and you willl come up with one.
