Jim Rosenthal
Where else would one begin to sell a flywheel....what I have here is a brand new, never used, custom-made flywheel for a Mark I GT40. It fits a small-block Ford with the old-style balancing. It was test-fitted to my engine but removed before dyno runs, so it has NO actual engine time on it at all. It comes with ring gear which will fit a Ford starter when mounted on the original-style Mark I bellhousing. This is a completely custom-machined part.
Note that this item is intended for use with an AP or Tilton multi-plate clutch as per the original Mark I cars, although it has not been drilled for that yet. You get to do that part.
Price: $1200.00 Contact me at jimbo1907 (at) comcast.net
Why didn't we use it? Because I wanted a streetable 10.5" Ford clutch in 1149, which doesn't fit inside the Mark I bellhousing.
