'73 Pantera w/8,400 orig. mi.
Lynn Larsen
Lynn Larsen
Auction ended with reserve not met at $35,000.00
Current bid: US $24,655.55 (25bids) - Reserve not met
Seller's Description:
8400 ORIGINAL MILES on this 1973 Detomaso Pantera with Air Conditioning, this is about as close too an NOS car as you could get. If you are into FORD RACING/SVT this car is a must to go along with your Shelby's, Cobra's and GT 40. This car has been stored here in nice DRY El Paso Texas since around 1976 and it is solid. The car original all the way down to the tires. It is Power by the 351 Cleveland Ford engine with the ZF 5 speed transaxle. The car does run and sound good. It has only had about 100 miles put on it since 1983. We recently had all the fluids changed before starting it up and running it again.
'73 Panera
This car is not pristine, so check it out -- Lynn
