WTB 351c weber manifold
I am looking for a 351c weber manifold to cut up and use with a set of Yates heads. I have been looking but it is pretty hard to find. I have access to a set of Italian webers that I would like to use and most companies won't sell just the manifold. Any help would be appreciated.
Doug S.
Love the 351C!!!!!
Check out post # 10 in this thread: http://www.gt40s.com/forum/tech-eng...rack-boss-manifold-302-w-351-c-2-v-heads.html
That is one of our forum members who used stack injection on his 351C. It is THE build that makes me drool--great look. I realize you won't be using stack injection, but you might just be able to source and modify the Redline manifold Dave uses to mount Webers.
Another forum member has modified a Yates manifold to use Webers. Here's the thread to that discussion, post #4: http://www.gt40s.com/forum/poll-place/18562-what-type-induction-you-using.html#post172968
Good luck!
Doug
As far as I know the 'redline' manifolds are still available out here, but as they are designed for the 351c 2v production head they would require all the bolt holes to be welded up & relocated to fit your 'yates' heads which locate the inlet ports well above that of the std ford placement. then you will need to cut away the valley area & fabricate a valley plate. I had forgotten this but I made and cast an IDA manifold[3 piece] years ago for a 351c. Will check it out and see if the guy still has the patterns/castings. PM me if your interested.
Jac Mac
