Alex Hirsbrunner
Hi Folks,
I'm wondering what you may be using to do your final attachment of the lower edge of the rocker panel to the corresponding flange on the chassis. As RCR-40 owners probably know, the arrangement is the bottom edge of the rocker is above the flange on the chassis, and access seems to demand a pre-located nut on the backside of the FRP rocker panel. I'm considering using fold-clips (see below - you probably call them something else) but these are intended for steel and don't spread out the load very much, and two sided tape seems so after-market
Thanks & Best Regards,
Al
Al
