Carb recommendation
Im looking for a new carburetter to replace an old Holley vac sec. 600cfm #1850.
i currently have a 300bhp 302 that is purely for the street use.It has big valve heads, 9:1 compression ratio and a street cam .I want a manual choke and something less than $400. It needs to be street driveable with good gas mileage on low throttle settings. People have recommended the Holley 4150 Double pumper or the street avenger . How do these carbs compare in terms of gas mileage and horsepower over my old 600cfm set up ?
Any recommendations?
:wrongforum:
YOU ARE POSTING IN THE TRANSAXLE/DRIVETRAIN SECTION, YOU MIGHT WANT TO PLACE THIS IN THE PARTS OR SERVICES WANTED SECTION OR THE ENGINE SECTION!!! YOU MIGHT FIND BETTER LUCK THERE.
BY THE WAY I WOULD RECOMEND THE STREET AVENGER SETUP, EASY TO TUNE AND CHANGE JETS AND I AM RUNNING A SIMILAR SETUP ON A 9'' LIFTED BRONCO, RUNNING A CRATE 302 FROM FORD RACING WITH A GT40 VALVETRAIN AND IT'S GETTING ABOUT 9.5-1 COMPRESSION. IT TURNS 38'' TIRES THROUGH AN AUTO C6 AND I AM GETTING ABOUT 9 - 12 MILES TO THE GALLON ON 4.56 GEARS, YOU WILL PROB GET BETTER GAS MILEAGE LOL!!!!!
THE DOUBLE PUMPER 4150 IN MY BELIEF IS A BETTER CARB TO TUNE FOR MORE PERFORMANCE, MORE AFTERMARKET MAIN BODIES AND OTHER SUCH TRICK THINGS. I WOULD RECOMEND IT OVER THE STREET AVENGER ONLY IF YOUR EXPERIENCED WITH TUNING CARBS AND DESIRE MORE PERFORMANCE, THE STREET AVENGER IS AN EASIER CARB TO DEAL WITH.
RON IF YOU SEE THIS POST, COULD YOU PLEASE MOVE THIS TO THE ENGINE FORUM.
