Has anyone used the Honda S2000 as a start button? I need to know the wiring for the switch. There are 5 pin connectors in the back of the switch which are not your typical spade connectors. I have the wiring diagram, but it doesn't show which pin does which function. It also only shows four wires. Any help would be greatly appreciated. I am headed out to a Honda only bone yard to see if they have a connector or any help at all. Other models of Hondas use a start button as well, but I don't know if they are wired the same. Thanks in advance.
