Ron McCall
Well,it finally happened!! I have 4 miles on the odometer! I'm so excited I han hardly type.I just made a few short "shake down" runs tonight.Tomorrow
I need to get a timing light on the engine and go over all of the bolts before I put any more miles on it.Everything went very smoothly.I need to adjust the brakes,suspension,clutch ,valvetrain,etc.....One thing I was worried about with the aluminum chassis was heat transfer through the tunnel from the coolant tubes.This does not seem to be a problem at all! driving with the cover ,above the foot box, off does!! The air from the radiator blows directly in on your feet! I warmed the car up and drove it 2 miles,when i got back,I noticed the temp was about 200deg.I remembered that I unplugged the hard wired fan so I turned on the aux fan and within 2 mins the temp was 180.I turned off the aux fan and plugged in the primary fan and went for another drive.(car idled for about 10 mins) When I got back,the temp was steady on 180deg. It looks like my electric pump set up works pretty well under cruising conditions.In May,we'll see how it does on the track!!!
Later
Later
