Well, I spent Sunday driving around sorting things out. It was really the first time I spent Quality time in the car after it was "finished". I would like to share a few observations. Just a note. The car weighs 2740 lbs with My 210 lb rear end in the seat and 10 gallons in each tank (20gal x 8 lbs per gal = 160 lbs). My total ballast was 370 lbs. That leaves a wet car at 2370lbs. This with 3.5 gals of oil, full roll cage and AC! epper: Let me say that with 600+ hp this is quite a ride. The car felt very stable and I did not experience any bump steer issues, which I had expected based on conversations on the forum. I installed a bump steer kit from Steeda for a 94-2004 mustang. Apparently it worked. The car felt really stable. My brakes work exceptionally well. They do drag as I am taking off and with race pads, it squeals. Fran gave me some advice to address this problem but I am open to suggestions. My AC was not working well. I am going to have it check to make sure it was filled properly. It held a good vacuum but we will see. The car ran around 180 deg with the oil around 200 deg. I really wasn't running to hard so I hope the oil doesn't run hot later on the track. I could always add a cooler. I had no leaks. The speedometer doesn't work but I haven't added the extra parts sent by Classic Instruments. The fuel gauge reads back wards and the fuel pressure gauge is not accurate. The engine was not running well. My "expert" had the wrong idle jets installed. I fixed that but I have not ran the engine on my A/F meter to check. It feels a lot better now. I am sure there will be more tuning needed. Finally, there is an annoying squeak in the front somewhere that is going to drive me nuts!:dead:I am going to start taking things off this weekend to find the little noise maker.
Overall the car was incredible. For a first experience I would give it an A+. The car is actually quite roomy on the inside. I am 6'3'' and it fits me very well. It is rough riding and loud and hard to see out of. Thats all good. I have taken first drives in a couple other cars and not made it back so with that as a yard stick, this day was a roaring success. It is really nice to report that the car is done and I am moving on to the tuning stage. I am very happy with the car, and RCR. Thanks to everyone that helped on this, I really appreciate all your help. This forum is fantastic.
