Has anyone found a replacement starter for the 930. The standard starter is quite heavy, and bulky. I am also running into the problem of alignment of the starter with its mounting holes. because I have lowered and moved the engine forward, the starter will not lineup with the mounting holes. It is not clockable, but I can weld on some ears to make it work. Has anyone used another starter in the stock location? If so are there any alignment issues?
Thanks,
Thanks,
