WANTED 289 crank!!!
Looking for SBF forged or steel crank any condition
Bernie
Scat will make a custom forged with any stroke from 2.75" thru 3.50", I assume eagle-Lunati-Crower etc will do same. Any Forged/Steel crank for 289 @ 2.87" stroke will be aftermarket or cut down Boss/SVO 302 Forging ( 302 offset ground 0.125" to 2.875" stroke with 2.00" rod journal ( Small SBC ) or go all out to Honda journal 1.88".
Kevin Box
Are you looking for an original and how much do you want to pay.
There is one in Hamilton (NZ) that I can get hold of and if you like i will chase it up.
I dont think it would be more than $200 NZ
Rob
Peruch,
Where are you located (not shown in your avitar)?
I know I have at least one or two original cranks in the basement. Are you looking for OE or aftermarket?
All manufacturers are long delay,Crower is OK for ten and delivery next july !!!!!,I' think easy way is to destroke a 302,thank you for your replies.I'm located in France
I'm with Jac - I'd offset grind it for a 2" journal.
Not personally sold on the Honda journals for anything other than a drag car..
Ford Motorsport/SVO used to sell a semi finished forging under p/n M-6302-A302 which could accomodate 2.700" to 3.300" stroke with 2.000" rod journal. Might be worth a look to see if still available. Would imagine that $$$ cost of final product would be high on doing it yourself on one of basis, plus nitride treatment.
