Jeff,
How did you notice the bearing problem (sounded great on the video)? I had the wheels off to fit some Avon tires and was performing a general check for tightness, slop, run-out, ect. While spinning the tire I noticed the sound.
Did you install new bearings? I did not replace the bearings. There was no sign of abnormal wear on the bearings so I decided to give them a thorough cleaning and repack them with hi-temp synthetic grease. That said I will most likely replace them at the next inspection.
Did you fab yourself and if so please share or get from SPF proper grease seals? I replaced all parts as they were. I agree some actual seals would be great.
Tx, Steve
PS...So far I havent noticed any wear or noise at 3,000 miles but, better seals will be an improvement if available.
