I only have a few more questions
So my choices include an in-tank pump (as recommended by Kinsler - their part #10271) or possibly the slick external Purolator-Facet pump that Big-Foot has used (see Chuck and Ryan's build thread). I know that you can burn up a pump if you let it run dry with low fuel under braking. I also know it is not the best to suck on gas too much (though your results may vary) as with an external pump.
I like the Purolator pump because it can run for a long time dry. I like the in-tank pump because it will push instead of pull. But mechanical pumps pull...?
Can others share experience? Not having a lot of success searching, as not that many are running EFI, and many more still are doing in-tank baffles and the like, which I cannot do.
And if you do run an in-tank pump (brace yourself for the really dumb question) how the hell are you mounting the pump?
As usual, my thanks. -J.
