I have a pair of fuel tanks that came with my GTD.
They are made to fit the GTD and they fit fine.
There are two problems I have with the tanks and I am just wondering if I am being over fussy or if it's something I need to have done.
The tanks were built with no baffles, is fuel "slosh" a huge problem on road cars?
Rather than being at the bottom rear of the tank, the fuel pickup is a pipe thats screwed into the top of the tank. is this good, bad etc
I could fill the tank with foam to stop the fuel sloshing about, but then I'd have to change the senders (see previous "capacitance" post)
The tank have had fuel in the, at sometime so they do need a proper clean before and work's done on them.
Now I am prepared to have the tops cut off and a couple of baffles fitted as well as having the outlet position changed if I really need it done (I'd rather do it now than later) but am I being a bit pickey or is it the right thing to do?
As always, any/all advice greatly appreciated.
Simon
Simon
