I am hard pressed to see what you guys are running that takes over 100 amps in a GT!
Uless you have installed a competition level sound system with high draw amps, electric water pump, extra fans for the AC, etc. I can't add up a draw that comes close to 100 amps! Also, I think the concern might really be the amperage available at low RPMs as compared to the max amps an alternator can provide. Spinning at 3000 engine RPM a 100 amp rated alt is fine but what does it put out at 1000-1200 RPMs? Many of the high amp units do not have much output at low rpm. If street driving with extended red light idle an AC running, etc. is in the plans, I would look at low speed output more than the rated "max" output. For the time where the output is exceeded by the draw, well that's what a good battery is for!
Also consider that alternator output goes down as ambient temperature goes up. The alternator in a GT40 is in a spot where cooling airflow is minimal. That 200 amp unit might only be delivering 130-140 at the temp it is operating in. Something else to consider.
JMHO
