Hey guys, I purhcased this fuel pump a while back, but I want to be sure I am going to be ok here. It's the Facet Duralift pump. I'm not interested in going a different direction unless the pump just isn't sufficient. Thanks for your input.
Dyno #'s!
When you need a tough, hard working fuel pump, with a minimum lift of 10 feet, these fuel pumps provide outputs up to 125 liters per hour, 11.5 psi .76 bar. In thousands of proven on-the-job applications, these pumps have earned the reputation to wear the name – Facet.
Dyno #'s!
