Hi there -
Yep, Dave's R42 has a Nos system installed. Has about 450-500HP as standard from a 6.3L Small block Chevy with Motec management. When he tried the Nos at Brighton a couple of years back, it definately worked well, although the 150HP hit broke traction in 1st through 3rd each time it kicked it. Dave had not intended to use it in 1st but a little over-zealous pedal use saw it light up the rears. In 1st and 2nd the back end kicked out to the right each time - oops! (on wide slicks)
He reported that the engine became 'incredibly smooth, almost tubine like' but a problem with the alternator bracket causing a thrown belt and damaged Nos line stopped further play that year.
He still has an intermittant problem with the motor, seems to be ignition/injection related and we think it is a sensor issue but still not confirmed. He thinks there may be an underlying mechanical issue so may well pull the motor for a quick look see. (not Nos related I hasten to add).
Ray Christopher has been playing recently with his modified type 34 Ford look-a-like, which powered by a 440 baracuda motor, now also sports a 100-150 shot of Nos too. He is very encouraged - and immediately knocked over a second off his quarter times. (mid 10s?)
I helped with another club member's Supercharged GTS Viper last year, which had a fully programmable Nitrous controller, very slick as you could dial in delays, initial hit and ramp rates for each gear... One thing to watch is the torque, which will increase immensely when the Nos hits, especially at lower RPM. On the Dyno, we set Viper's Nos to start at 10% and ramp up to 50% of what was available over a 1 second time period but to not come on below 3000rpm.
Results were impressive - the motor was pulling hard and had approx 500HP 'at the wheels', when the Nos kicked in, power instantly jumped to 730HP and the indicated torque was 869ft lbs at 3100rpm - eek!
An interesting trip to the drag strip followed, where we dabbled with power levels up to 100% of available, (deliberately left larger jets at home!) and it was interesting just how much can be used and how fast it can be ramped up on a prepared track.
Finally, I've just fitted a
MOTTY AFR TUNER to my GSX1400 which is proving fun and I notice the latest firmware upgrade includes an option to dial in fuel enrichment via injectors for a dry nitrous setup -
:idea:
hmmmmm - I wonder......
(when are you next over Ron? - will be ready for use when you are :thumbsup
