I have the classic style Smiths gauges in my GTD and the water temp and fuel gauges have stopped working. I am shockingly (pun intended) inept when volts are involved and am hoping someone can help diagnose what is likely quite obvious to someone with the right experience (not me).
I suspect the voltage stabilizer is faulty as I get 13v on the "in" (I assume) tabs and the "out" tabs produce fluctuating voltage that swings rapidly from less than 1v to 10v or more (as shown on my digital multi-meter). I assumed the output should be a pretty solid 10v or so.
Any thoughts as to what is going on here? Suggestions? Is it likely that the old VS just packed up and is there any simple way to test the functionality of it?
If it is dead, any thoughts on replacement sources?
Thanks!
Mark
Thanks!
Mark
