I’d like to get my car running and maybe drive it to Road America but I still have a ton of things to take care of.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com<img src=" /><o></o>
I see most people mount one or more fuel pumps on the left rear bulkhead and some have one down near the tank with all sorts of swirl pots and filters. <o></o>
<o></o>
The problem is at this point I just want to get the car so I can drive it, right now simple is good.
<o></o>
<o></o>
I bought a 100GPH Carter fuel pump and the instruction say to mount it as low and close to the tank as possible. Apparently it’s better at pushing than pulling. Does anyone have a different opinion? Also if the pump is down by the tank should the regulator be down with the pump or up by the carb?
<o></o>
<o></o>
I currently have the gas tanks out of the car and plan to clean them. Will vacuuming them out be good enough or should I also slosh some solvent around in them. I read somewhere on the site that someone had a fuel filter they could take apart and clean, does anyone know what the make and model is?
<o></o>
<o></o>
Thanks again for the help.<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
