2 days back I had the Dax through it's MOT inspection for the first time as it is now 3 years old.
It is a 1990 rover engine 3.9l running the Bosch "hotwire system" with lambda sensors in. The heads have been extensively worked to improve breathing and the whole engine balanced by John eales of Britihs Racing fame
Now the specifications it must meat on emissions are based on the engine year so must meet
Max % CO of 3.5 acheives0.31%
Max HC 0.12 acheives 927ppm
The engine has been idling for about 15 mins with fans cycling on and off before the test so she was HOT
So what do these readings say about engine tune - lean rich or OK?
Thanks for any advice
