I would like to design a circuit that when triggered with a one amp signal that would last for thirty seconds max, would trigger a relay to run for 2-4 minutes. It is called an off delay relay. I have found some stuff on the internet but not sure how it should be wired or how to assemble a board to make it work, or where to just find a circuit. It should work like when you turn off your ignition but your lights stay on for a minute of two.
The things I have found are for A/C units in the 12 volt range as seen here:
I understand the concept, just need some help.
