I'm still in the process of "sorting" my car and like most of us once an issue is cured another pops up. So is the case with my GT40. I need input on the following issues with my Smith Gauges and would appreciate any insight before I take the entire car apart to rewire the whole damn thing. :shy: First the speedo. Its a replica of course and electric not mechanical. It has never worked properly. I've replaced the pick/up at the transaxle mount and insured its proper gap from the pick ups. I've rebuilt the very weak connector found at the rear of the car and have noted power getting to the gauge because the lite works and the oddmeter while stuck on 28.3 miles is now showing 28.5 miles even though I've driven the car well over 250 miles since. At times, I'll notice the needle jumps a wee bit when I turn on another electical component but then returns to zero. Ground?
The fuel guage that used to work perfectly is now ONLY working off of one tank. The toggle switch is a 3 position switch. Off, driver side tank (first click) and passenger side tank (second click). When I click the switch for the driver side tank I hear the fuel pump come on but no movement from the needle on the gauge. Everything else on the gauge works. I've made sure there is fuel in the tank, checked the terminals on the guage, checked the leads going to the sending unit and see no problems. I have not removed the sending unit from the tank.....yet. Sending unit.....even though the car only has about 500 total miles it?
Lastly, the lite is out on the tach and I've checked the bulb and it appears to be good. Thanks for whatever you can offer.
