Tim Kay
I would also recommend that you place your fill tank with pressure cap so that the line from the fill/pressure tank connects to the system at the suction side of the pump. This will set the point of zero pressure change in the system and insure proper operation of pressure cap. This is not as important with a constant flow electric pump as it is with a mechanical pump but still recommended.
<!-- google_ad_section_start(weight=ignore) -->Mike Trusty
I saw this quote on a recent thread which made me wonder if this was the reason for my expansion tank failure 2 days ago in which a welded seam burst. After r&r coolant and purging all the air from the system the motor ran cool for 40 freeway miles. Shortly after exiting the freeway the tank burst.
I had surmised that due to excessive steam build up during my bleeding procedure of the water system I must have initiated a crack in the expansion tank.
Down stream from the manifold \ thermostat is where my expansion tank feeds into the radiator return line (I use a mechanical water pump).
1) Is there pressure into my expansion tank using this location?
2) How does locaton of the fill line affect the operation of the pressure cap?
3) Would the location of my fill line be the reason the initiated crack devoloped further?
4) My pressure cap is 20#, is that too high?
