In the Dax I have a Morgan engine (3.9litre) (Same as Rover / TVR V8 but actually came with Morgan numbers)
It is currently fuelled using the Lucas "Hotwire" system of fuel injection, however as the engine has been modified with bigger valves, porting, balancing, raising CR, pocketing pistons etc the injection system cannot cope too well. Cam specs were discussed here http://www.gt40s.com/forum/gt40-tech-engines-induction-exhaust/20038-rover-engine-cam-specs.html
I am reluctant to change the cam - sort of it it ain't broke don't fix it and the fuelling seems to be "causing " the problem
The motor great when you ask for power or acceleration and at Santapod did almost the same time and speed as other GT40's fitted with Ford 302 motors, but at low throtle and low revs 1500 - 1900rpm in traffic she kicks and bucks as the overlap confuses the ECU and it says "too lean" and then "too rich" and causes a kangaroo effect.
I have got around this in the past by running in a lower gear and having the engine rev higher but this again gety tyring (not to mention hot and noisy)
So time to get things to work better.
Options are (or ones that I have found)
1) Have Megasquirt supplied and fitted and mapped - this will still use the plenum etc of the existing system but be mappable and also run the sparks through coilpacks (£1500)
2) Remove the injection and fit a manifold and Holley - the carb will be less fuel efficient but as I maxed at 3000 miles in a year will not make too much difference in running costs. The Holley would be 390cfm which some say could be too small at WOT (£780)
3) Remove the injection and fit a manifold and Edelbrock / Weber 500 - Which some say is a better carb (£780 fitted or about £500 for the bits)
4) Quad Webbers / Delortos and manifold and tuning (£2500 - £3000 and outside my budget)
Options 2 & 3 retain the current distributor system which appears to work reasonably.
Option 1 and existing are EFi which in my opinion are OK but not really in keeping with a GT40
So what is the better carb to use? Holley would require more setting up time and is potentially too small at WOT, Weber is said to be really easy to set up and tune but is not recomended for racing - around corners fuel can cause lean or rich running.
And yes I have Scottish blood so want to spend as little as possible to get a more "easy to live with" car
What's your thoughts?
