Solenoid valve
I would like to run a return fuel line from my Webers back to the tank( R or L). I need some sort of valve to direct it back to the tank which is being used. Any suggestions?
I have done it with a restrictor pellet in the return line.
It will be a surprisingly small hole,but the hole will be relative to your pumps ability and how much you need to bleed of.
I did it through trial and error.
A needle valve may be an easy way rather than pellets.
Jim
